Wait for light or not?
RE: Wait for light or not?
ORIGINAL: pvbjr
Dealer and manual tell you to wait for the light to go off, what the ECM is doing is checking air temp, filling fuel pump etc. it will start if you don't wait but I'm going by the manual.
SKRATCH - When I bought my '01 RK was told this from the dealer on purchase - Maybe 6 months later set a code and took it to the Shop and was questioned if I waited for the light to go off before starting - They cleared the codes and it never returned...
Happened also to another friends bike "05 Ultra - SAME STORY...
If you had to wait for the lite to go out it would say so in the manual. Ever see all those warnings about this and that.
That salesman who sold you the bike might have worked at Burger King last week.
You can't compare a 01-04 to a 07.
If the ECM needed to reset itself, it would not take it 4 seconds.
i'll look for that.
i am not pretending to be an expert in the matter, and i am always open to learn. however, wasn't there a memo posted earlier from some pd saying that they got with hd and that not waiting for the light would not hurt anything?
also, it just seems to me that if it was what you had to do that the manual would specifically put a note in their saying something to the effect of: warning, not waiting for the engine light to extinguish before hitting the starter button will result in increased global warming, your hot neighbor will move out and some skanky crack hoe will move in etc...
kind of like this one: warning-do not operate vehicle with forks locked. locking the forks restricts the vehicles turning ability, which could result in death or serious injury.
Here it is:
The CEL (Check Engine Light) is an indicator of a SYSTEMS CHECK...
Just like booting up your home PC......
When you initiate the start sequence, you are powering all components up to their required levels, engage the Run/Stop switch, now you are ACTIVATING the ECM to begin it Enviromental/Systems/Actuator check process....
The sensors in the TBI unit need to gather atmospheric data, the fuel pump spools up to 55 psi, the ION sense is engaged, injectors are primed, and IAC applies the required amount of steps to accomodate a proper Fuel Start value with the ET....
By "Beating the Clock", you are temporarily cheating the ECM into thinking that the enviromental aspects are what they are when the system is energized, and they (Sensors), don't have a chance to level out their readings....
Does this hurt the vehicle, prolly not, as once the bike is running, the sensors will continue sending data to the ECM for the actuators to follow, but it is unknown if it affects the ECMs operation, as it is not allowed to do a FULL BOOT SEQUENCE......
FWIW, Jamie, as well as Powercommander will say that the PC does NOT INTERCEPT the signals that have to do with the start up sequence..... Seems as though there are a few here that are experiencing something that is not supposed to happen... Hmmmmmm...
ORIGINAL: Spartan
so technically speaking, it isn't intercepting those signals, but a different one?
Well put me in the not waiting catagory. I turn the key and hit the start button on all my bikes! Seems to be the same if I wait or don't wait. Personally I like not waiting. I used to do that with the RK and read somewhere it didn't matter so I haven't done it since.
ORIGINAL: skratch
that may be so, but i think its a matter of what people are perceiving to happen. the pciii may not be intercepting the signals, but the power to the pciii is definitely being shut off, then when you hit the start button, it has to go through its start up sequence again.
ORIGINAL: Spartan
ORIGINAL: maltezebluez96
Besides,....how long does it take for the light to go off? We're in a very fast passed world but a few seconds won't do any harm unless maybe your trying to get your wife that's in labor to the hospital
