How to get front brake master cylinder level?
Old 03-03-2017, 08:41 PM
Taggs's Avatar
Taggs
Taggs is offline
Originally Posted by albngore
Thanks. I do not notice any difference one way or the other. I have compared each position--on the jiffy stand or on the lift--each with left grip pulled in. Kind of odd since others notice a difference.
It will work fine the way I am doing it. I tend to find issues where none likely exist.
Not sure on your model year bike but the Rushmore 14 and up have a tiny vent hole in the cover gasket. It must be put back in the same position when reinstalling the cover. If a leak is a concern or occurs the cover gasket replaced should cure that leak.
Old 03-04-2017, 07:40 AM
albngore's Avatar
albngore
albngore is offline
Many people are unaware that there is an orientation issue with the cover and gasket. This is not mentioned in my service manual either. The correct way to replace both the cover and gasket is to put them back exactly the same way they came out.
Old 03-04-2017, 08:11 AM
ORradtech's Avatar
ORradtech
ORradtech is offline
And in this case none exists.
Get it as level as you easily can, protect the bike/paint and do the work.
You can bet your bippy HD doesn't loosen hand controls or get out a level to flush/repair brakes.
Bottom line here is that you have more combined time typing and responding to questions in your two threads on this than it will take to flush the brakes.
Old 03-04-2017, 08:31 AM
albngore's Avatar
albngore
albngore is offline
ORradtech has the best solution--just do it in the sensible way everyone else does. I pondered this level situation way too long.
Thanks.
Old 03-04-2017, 09:22 AM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,578 Likes on 1,970 Posts
I just did mine, on the jiffy stand about half way turned to the left was level.
Here's a good video:
https://www.youtube.com/watch?v=Jor9...ature=youtu.be
ryan9977
04-30-2019 04:35 PM
78lowshovel
Shovelhead
12-01-2014 11:38 AM
mrmikey32
07-11-2012 12:29 AM
DeiGratia
04-30-2012 01:14 PM
Skip
04-12-2006 12:55 AM
Quick Reply: How to get front brake master cylinder level?
