Shitty front brakes
Old 10-08-2005 | 03:17 AM
Quickie's Avatar
Quickie
Default Shitty front brakes
Hey guys, just wondering if anyone has any suggestions? Ater 5 thou on my road king I noticed a increasing surge while using the front brakes. At the service dealer told me my rotors were worped and replaced them. 5 thou more and the new rotors are the same. Next service told the dealer again and was told they won,t replace because its just normal for the harley brakes to surge due to worped rotors. Come time I need to replace, any suggestions for different front brake system?
Old 10-08-2005 | 07:49 AM
navyman's Avatar
navyman
Default RE: Shitty front brakes
12,000 miles on '04 RK and have not experienced any rotor warping.
Old 10-08-2005 | 11:25 AM
pilot1996's Avatar
pilot1996
Default RE: ****ty front brakes
9K, no warping...this is crap the dealer is handing you. Did they replace the pads, or only the rotor? When you replaced the rotor did they replace with stock or with an upgraded floating style rotor?
Mac
Old 10-08-2005 | 02:10 PM
pococj's Avatar
pococj
Still under warranty? Go to the HD hotline, whatever it's called, and tell them. Rotors don't warp without a cause. It can be either a material defect, an assembly problem, or even the rider causing the problem. Hard part is finding out which.
Old 10-08-2005 | 02:37 PM
screamn_eagle's Avatar
screamn_eagle
ive got 8 thou in this bike, had over 10 thou on the last one and never had a rotor warp. both of those bike did have the floating rotors i dont know if that has anything to do with it. i would do as skip says and call the moco and complain, you might get some satisfaction
Old 10-09-2005 | 12:12 AM
wild1's Avatar
wild1
I have the same thing on my 05 ultra. I have just lived with it. I have 12k kms on it.
Old 10-09-2005 | 12:49 AM
mikeisglidn's Avatar
mikeisglidn
12,000 no warpage here
Old 10-09-2005 | 10:57 AM
rapz's Avatar
rapz
There's no way rotor warping can be "normal", I'd demand they change them out as often as it takes until they get it right!
Old 10-09-2005 | 12:46 PM
luvmyflhtcui's Avatar
luvmyflhtcui
I had 63,000 on my 92 Softail and had no warping brakes at all. My 04 Ultra has had no brake problems except a little squeel from the back rotor, but I am going to replace all the rotors and pads with floating rotors this winter when I get the wheels chromed. You might want to look into a set of floating rotors. They don't squeel and I have never heard of on warping.
Good luck.
[IMG]local://upfiles/494/E1618D97C9764246A4CF94B0E58FBA74.jpg[/IMG]
Old 11-27-2009 | 04:03 PM
oley55's Avatar
oley55
my 07 Ultra has 30K on stock rotors and no warpage or brake surge.
my 08 roadglide has 15K floating H-D rotors and very serious surge. I also get a clank when first applying the brakes. I believe I have a bad caliper on the 08 with one (or more) piston/s not fully retracting. hence the worped rotor/s and clank. although under warranty, the rotors were installed after purchase and are out of the general BS added component warranty. trying to decide if I need to take it in under warranty about the clank, or on my own determine which rotor is worped and replace my self.
Quick Reply: Shitty front brakes
