Shitty front brakes
Old 11-27-2009 | 05:17 PM
dawg's Avatar
dawg
It would be a no brainer to me, if it's under warranty I'd make them fix it.
Old 11-27-2009 | 05:22 PM
FastHarley's Avatar
FastHarley
Former Sponsor
I have posted numerous times on this possible problem. Can you raise the tire off the ground and spin it. Is it rubbing against the pads and not getting a rotation or so before stopping.
Old 11-27-2009 | 06:23 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Veteran: Marine Corp
WOW! A four year old thread brought back to life!
Old 11-27-2009 | 06:28 PM
dawg's Avatar
dawg
Old 11-27-2009 | 07:09 PM
Harleypingman's Avatar
Harleypingman
Originally Posted by oley55
my 07 Ultra has 30K on stock rotors and no warpage or brake surge.
my 08 roadglide has 15K floating H-D rotors and very serious surge. I also get a clank when first applying the brakes. I believe I have a bad caliper on the 08 with one (or more) piston/s not fully retracting. hence the worped rotor/s and clank. although under warranty, the rotors were installed after purchase and are out of the general BS added component warranty. trying to decide if I need to take it in under warranty about the clank, or on my own determine which rotor is worped and replace my self.
Oley, got to ask how/why a four year old thread got your attention???
Old 11-27-2009 | 07:36 PM
dstegjas's Avatar
dstegjas
Same as most above, no warping on the front rotor. I would try to get them to either rebuild or replace the whole front caliper system. The only thing that I can think of is that it is not applying the same amount of pressure to both sides of the rotor. This might cause the warping. Not sure if that is the problem but I have seen this happen on cars.
Jim
EDIT: Crap, I didn't even look at the date of the orginal post.
Old 11-28-2009 | 02:33 AM
cole's Avatar
cole
Check to make sure the proper brake fluid is used and also that you have minimum free play at the brake lever. cole
Old 11-28-2009 | 04:59 AM
dog155's Avatar
dog155
In all my years have never had warped rotors.Have always used aftermarket pads for better braking power.Actually have used rotors off bikes that were takeoffs because were supposed to be warped.Lift the front wheel off the ground and spin it to see for yourself.
Keithhu
12-15-2013 10:45 AM
don g
07-08-2011 01:52 PM
k&j eglide
04-05-2010 12:43 PM
wescoot2
04-09-2008 09:26 PM
Cohiba_Joe
04-09-2008 01:00 PM
Quick Reply: Shitty front brakes
