Advice on Handle Bars
RE: Advice on Handle Bars
best to do it all at once and be done but if you are willing to try a few, I would start with a stock set of WideGlide bars pre -06, should be about $50 at the dealer for the bars. Many people like them on RoadGlide so it should be about the same. They will give you a more natural feel.
My suggestion is to hit a couple of the events/shows. I have seen Flanders set up at the indoor shows with a mock-upassembly that represents a MCand they would change the bars on it so you could get the feel for what you like. The next place is a decent HD dealer as some of them have the same mock-up assembly. What works for me and my build/size may not work for you. Age and broken bones along the path of life often dictate where your comfort zone is.
Wild 1 518's are the best add on I have made to my '06 Road King. They have a little more pull back are a little higher and wider than the stock bars. I put mine on in April of 07 and then took a 4800 mile trip out through Colorado, Wyoming and Montana and never had the first bit of back pain I had with the stock bars. If i were to get another Road King The first mod I would do is put 518's on it as soon as I could. After I put them ona few buddies saw them and so far 1 has changed over to them and another wants to soon. Handlebars are very subjective though, what is right for 1 may not be right for another. Try to sit as many different bikes as possible and go from there. Good luck!
Jeff
Jeff
