Found a screw up in the recessed part of my rear tire where I doubt it can be plugged?
Both tires are standard Harley/Dunlop. I would like to go with Commanders but can't afford front (which does not need to be replaced - good tread) and rear at the same time.
Ok to mix or should I just get another Dunlop to keep them matched. I would replace the front with a Commander when the time comes
if their stock,402,407,408 or american elite they should be bias for a harley.i believe there is a r in the size and load #"s on the sidewall if it radial.
