xm antenna fakra plug broken
Old 02-23-2017 | 05:19 PM
JABMIKE's Avatar
JABMIKE
Default xm antenna fakra plug broken
I have an xm module(76165-06a) and the pink Fakra connector on the piece coming from the xm unit has broken off. Anyone have a fix for it? i have found the part that is on the end of the antenna online but not the pink part attached to the back of the radio...
Attached Thumbnails xm antenna fakra plug broken-xm-module-1.jpg   xm antenna fakra plug broken-img_5031.jpg
Old 02-24-2017 | 07:09 AM
justmike911's Avatar
justmike911
Pic ?
Old 12-19-2018 | 04:54 PM
Hwyflyr's Avatar
Hwyflyr
Stage IV
Default Broken fakra plug resolved
i had called iron cross audio and they can replace the plug for $65. Just print out the form and add replace fakra plug On the form. I called today 12/19/2018 and talked to their tech and he said no problem but he did inform that it’s not really necessary as probably all the plugs are broken and to just attach it as securely as possible. I told him my antenna connector wasn’t very good either and it would be better to have it repaired. But they do repair them so alll is not lost. 👍👍
Old 12-20-2018 | 06:15 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Have you thought about taking the unit to a marine supply store, West Marine comes to mind. A lot of boat owners are /have gone to Sirius/XM in the last few years and the supply store might have what you need.
JABMIKE
Audio Systems
03-07-2017 10:40 AM
Rees107
Audio Systems
12-11-2016 10:26 PM
dennsco
12-08-2016 09:33 PM
craigffb
09-15-2013 08:20 AM
cellison1460
09-13-2012 12:10 AM
Quick Reply: xm antenna fakra plug broken
