OEM HD Fairing lowers vs Advan Black
I don't know who makes the advan black lowers
but this is the set I bought now cheaper than the $70 I paid shipped
http://www.ebay.com/itm/Black-Lower-...9TBCng&vxp=mtr
and this guy has them even cheaper
http://www.ebay.com/itm/Lower-Vented...1YiCXi&vxp=mtr
and this install kit because I will probably remove them once it gets HOT here for more air flow
http://www.ebay.com/itm/Quick-Change...VYnBYy&vxp=mtr
I do not like the 14 up lowers, I don't think those vents are large enough and even remove the grates over where radiators would sit I still don't think there would be enough air flow
My write up.
1HD1C (03-07-2017)
so did you try the blue yet. I have same color.
Color match is good as well as paint quality. Had to adjust one of glove box compartments, loosened three screws under cap and moved compartment over slightly. Easy install, no instructions by the way. Two small paint imperfections, tried to take pic but only shows up under fluorescent light. I had to point them out before my buddy could see them. One is behind highway peg, size of pinhead. Doors are not as tight as OEM. Latches also not as crisp. But work ok, factory ones do fit if you want to change. Saved over two hundred dollars over OEM so will see. If these do well I'll probably go for Advans chopped tour pack and stretched bags.
