Dear Klock Werks...
Old 02-23-2017, 12:02 PM
RandyL's Avatar
RandyL
RandyL is offline
I also recommend long ride shields. work quite well
Old 02-23-2017, 12:39 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
the LRS I have seen are quite different from the KW
oranges to grapefruit.
the LRS promise is to throw air over your head- the KW promise is to plant the front end.
Mike
tphillips (02-23-2017)
Old 02-23-2017, 02:02 PM
MilesOfTexas's Avatar
MilesOfTexas
MilesOfTexas is offline
Why I use Freedom Shields. No distortion at all and I can use an 8" with no buffeting (I am 5'10") on my '14 Limited.
Old 03-08-2017, 11:32 PM
sixgun95's Avatar
sixgun95
sixgun95 is offline
Since it seems like many OEMs measure the height differently (top of center screw, top of fairing, etc.), how tall is the stock HD shield on an Ultra?
Old 03-09-2017, 07:14 AM
GOV5's Avatar
GOV5
GOV5 is offline
Received 1,455 Likes on 933 Posts
On a 2015 Ultra, the stock shield is 10 inches high.
I'm 6'2", and the turbulence was awful. Had I known that, part of my negotiations at time of purchase would have been to change the shield to a 12", which I did later. I never thought to check the dimensions because my last Ultra had a 12" stock shield and no wind turbulence.
Btw, a person's height is not a real factor in determining what height the shield needs to be. I'm 6' 2", but only have a 32 inch pant seam. Most of my height is from waist up. If a same height person has a 34 inch inseam, he sits 2 inches farther DOWN in the saddle, and wind may never hit the rider at all.
Old 03-09-2017, 10:13 AM
Beak's Avatar
Beak
Beak is offline
Its a trial and error process, just like sound, wind is subjective. Some want none, others need a little. Down here in SW Fl its a trade off. You need the air to keep cool, but you need to block those bugs that are as big as birds also. I have a 8.5 Klock Werks smoked that is on my Ultra, I look over it and get no buffeting. 5'10 with a 30 inch inseam.
If you are the type that looks through the windscreen, you cannot run one with a lip or curve on the top. The distortion will be terrible.
As said, Helmets do make a difference. The fit, and design of the helmet can contribute to the turbulence you feel.
HuntWhenever
2018+ Softail Models
58
11-09-2020 09:54 PM
bigbadpoppa
02-18-2016 12:38 PM
Robert_W
01-04-2012 08:08 PM
thewholehog
04-29-2011 10:27 AM
WVICEMAN
03-14-2007 05:36 PM
Quick Reply: Dear Klock Werks...
