Wheel fitment question
Old 02-25-2017 | 12:37 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by bwoltz
Thanks,
Definitely a solution. Trim 6mm off each side spacer will work.. PITA if you don't have a lathe. Got a lathe? Cut the axle to 25mm.
Vertical Mill...spacers, yes, but it doesn't lend itself to axles very well
Also you can buy 1x15mm bearings
Old 02-25-2017 | 12:52 AM
Max Headflow's Avatar
Max Headflow
I've done the narrow bearing thing but the 1 in 6205 bearings were crap.. IIRC Amazon had some Nachi listed but when I went to order they were listed as discontinued. It's easier to get std sealed 6205s.. While they don't last as well as the wider bearings they are easy to get.
Old 02-25-2017 | 12:55 AM
johnnynitro's Avatar
johnnynitro
Like bigskyroadglide said Just buy the 25mm axel/Spacers And put your old discs on
Max Headflow (02-25-2017)
Old 02-25-2017 | 01:02 AM
multihdrdr's Avatar
multihdrdr
You can get skf 1x15mm...good enough?
Old 02-25-2017 | 01:16 AM
Max Headflow
Where?
Old 02-25-2017 | 08:50 AM
multihdrdr's Avatar
multihdrdr
skf 6205VSP25
Old 02-25-2017 | 09:24 AM
Max Headflow
Thanks,
Even tho I've converted my stuff to 25mm..
Cozz
07-18-2017 08:03 PM
Infinite_Day
12-13-2013 09:47 AM
SpiderPig
06-27-2013 10:28 PM
H.D.FatBoy
08-06-2012 06:34 PM
niermeyer
Wheels/Tires
05-10-2011 02:48 PM
Quick Reply: Wheel fitment question
