installing accessory switches
ok i installed the switches on the left side of my ignition on my 14 SGS. plugged in the harness and now i cannot find the power wire ,, is it in the fairing? the switch illuminates and functions good,, just cant find the power wire for the lights im installing, where should i be looking?
Need a little more info on what you have going on.
1) How many switches did you install on the left side?
2) You plugged in what harness?
Looking at the switches from left to right...
1st one operates the factory passing lamps on my Limited.
2nd one I added which operates the engine guard fog lamps
3rd one I added which operates the heated seat
Now that the switches are in, go under the left side cover and find the tan-ish 8-pin connector. That's the accessory connector where I'm about to plug my harness into
Since you have the switches installed, you should need harness 69200722 from HD to plug into the accessory connector under the left side panel. That's where your dash switched power source is. I have my fog lamps hooked up to the 'loose' pig-tails on the harness which is controlled by the middle dash switch.
18 SGS Accessory wiring harness install
Just bought an accessory kit with switches to run my soon to be installed led lighting. Got the switches plugged in and mounted and then found the black mod connector where I’m supposed to insert the fuse holder in pin 3 location. There’s a white plastic piece inside not allowing me to push the pin in and I cannot figure out how to get the actual connector apart to remove this and get the fuse harness wire pushed in. Anyone got a link to better instructions than what come with it or videos that’ll help?
Thxs
Thxs
NotAknucklehead
2014-2023 Touring Models
06-12-2019 07:10 AM
