2016 streetglide fork clamp pinch bolt torque specs needed???
anyone have torque specs for the 2016 street glide fork clamp pinch bolts. if you have the caliper and axle nut and axle pinch bolt torque that would be great as well. I found a few specs online but want to be sure there correct. I'm ordering a manual but need the specs now. Thanks for the help
Video I watched from the company I got my new fork cartridges from said the service manual says 20 ft/lbs, but even that doesn't seem like much. After install and a short ride, the fork tubes have slid up in the tree's. Idk exactly how much, but there's definitely more showing that when I initially installed them back on the bike. Any help is appreciated. Thanks.
14-18 ft/lbs just doesn't seem like it's enough.
Ya. Thats what the guy said in the video. I think it was top, bottom, top, bottom. Which is what i did. Thanks. I think ill call my local MoCo later.
Service manual calls for 14-18 ft lbs; I recently put mine together and just rechecked torque the other day. Haven't had any issue w/tubes riding up in trees, but I did clean up the bores in trees with a little emory cloth prior to assembling so you might give that a try.
