Bassani 2x2 dual head pipe pn#1F14A
Old 02-16-2017 | 05:29 PM
SgtMic's Avatar
SgtMic
Here is mine.
Old 02-16-2017 | 06:12 PM
fournierrandy's Avatar
fournierrandy
Originally Posted by SgtMic
Here is mine.
That is perfect. Thank you
Old 02-16-2017 | 06:45 PM
SgtMic's Avatar
SgtMic
Installing these onto the heads was pretty simple. Getting these Rhinehart mufflers on is a different story.
I may end up grinding away at some of the chroming. It's fairly thick.
Old 03-21-2017 | 12:14 AM
Dillon Jones's Avatar
Dillon Jones
Stage II
Default Help
Originally Posted by jake24lt
I put one on my 2016 FLHX. Fit perfect withe exception of the crossover pipe that feeds the left side muffler. Had to do a little tweak to get the bolt that goes through the bracket( that is welded to the pipe) to thread into the oil pan.
The Harley bracket wraps around the pipe and can be moved. Heat shields fit well and no leaks at all.
2 things I liked about the kit were, that it comes with both sets of O2 bungs. Stock location (narrow band) and wide band up by the exhaust ports. It has plugs for both.
Also the crossover pipe that runs from the right side to the left side feeding the left muffler, is a round full sized pipe and not the piece Harley installs that looks like someone smashed it with a sledge hammer! Not sure why Harley chose to do that seeing as the oil pan hangs down lower than the pipe anyway.
What kind of tweak did you have to do? I tried for 5 hours straight trying to get that crossover pipe on my 15 Road Glide yesterday and I swore they gave me the wrong pipes.
Old 03-21-2017 | 05:15 AM
jake24lt's Avatar
jake24lt
Default crossover
I had to bend the hanger bracket a bit to get it to line up with the bolt hole in the oil pan.Also, make sure you leave everything loose so you can get everything hung on the bike , then tighten.
Old 03-21-2017 | 01:18 PM
Dillon Jones
Stage II
okay thank you I'll try it
Old Today | 01:20 PM
Leimy's Avatar
Leimy
Old thread. Any other comments ?
Bassani 2x2 2 Into 2 Dual Head Pipes
fournierrandy
Exhaust System Topics
02-21-2021 09:56 AM
Anniversary03
06-20-2018 01:06 PM
flashracer
Milwaukee Eight (M8)
07-19-2017 08:32 AM
blackflame
05-09-2017 07:52 AM
GregGillette
01-29-2017 09:44 PM
Quick Reply: Bassani 2x2 dual head pipe pn#1F14A
