Hyd Cam Tensioner Wear
Old 02-10-2017 | 06:14 PM
liquidr1's Avatar
liquidr1
Search for the post, but a member here posted just a few weeks ago his hydraulic tensioners failed at a very low milage. The metal pistons under the plastic were exposed they were worn so bad.
Old 02-10-2017 | 06:31 PM
EdwardK's Avatar
EdwardK
Originally Posted by partsguymatt
I'm picking up an 09 with 23k, and had been reading horror stories about these chain followers on the twin cam engines. I'm used to dealing with them on cars, but some of these internet freakout artists are making it sound a lot worse. Thanks for the post. That being said, I'm still going to pull the cover and have a peek.
What you're probably seeing are threads on the old spring tensioners. They were a nightmare of not checked regularly but the new hydraulics with the roller chain have proven to be dependable and long lasting. As in the previous post, anything mechanical can fail prematurely but the new set up is much much better than the old. The 09 you're looking at is just getting broken in good at 23K.
Old 02-10-2017 | 06:51 PM
Classic 10's Avatar
Classic 10
Bmaier Great! Yep ya may as well replace while you're there.
Old 02-10-2017 | 07:00 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Some good info on the hyd. shoes, thanks Classic 10.
Old 02-11-2017 | 08:36 AM
SpiderPig's Avatar
SpiderPig
Thank you for taking your time to post about these. Real life conditions are valuable to all of us. Good job!
Old 02-11-2017 | 09:38 AM
liquidr1's Avatar
liquidr1
Here is the post I was referring too. guys bike had less than 50K miles. Look at the pics. Im sure its a rare case as most have reported many thousands of miles on the original tensioner shoes.
https://www.hdforums.com/forum/touri...let-loose.html
Old 02-11-2017 | 10:10 AM
EdwardK's Avatar
EdwardK
I remember reading that thread. I'm not saying it's the cause of the failure but the engine in that thread had a ton of mods done to it and he talks about how hard he rides. The more performance mods, the more reliability becomes questionable. Even his indy builder was surprised and had no clue.
Old 02-11-2017 | 10:25 AM
multihdrdr's Avatar
multihdrdr
...Anomaly
Old 02-11-2017 | 10:28 AM
Big Dave's Avatar
Big Dave
But he only ran it out of oil once
Dave
Old 02-11-2017 | 06:26 PM
farmboy555's Avatar
farmboy555
Thanks for sharing the info, I've got 56,000 on mine. Plan on just keep riding
Quick Reply: Hyd Cam Tensioner Wear
