Accessory Switch
Old 01-27-2017 | 01:57 PM
Blue Tick's Avatar
Blue Tick
Default Accessory Switch
I am looking to add an accessory switch or 2 to my bike for to operate some added lighting. I really don't want to buy the high $$$ plug from HD. For those that have not used the HD switches, what did you use? Can you post some pics please? I'm looking for options/alternatives.
Thanks in advance.
Old 01-27-2017 | 02:53 PM
mkguitar's Avatar
mkguitar
more specific, what are you adding and where, what year and model bike?
how do you want to control this lighting on with bike or on all the time ( like leds highlighting a parked motorcycle)
mike
Old 01-27-2017 | 07:49 PM
just plain john's Avatar
just plain john
You need to consider the load. High amperage loads need to go through a relay, but you can operate a relay with an accessory switch. The switch itself isn't rated for a high current load.
Old 01-28-2017 | 08:19 PM
Blue Tick's Avatar
Blue Tick
These aren't high amperage lights. Wanting to run some LED strobes. They will be under a fuse/relay from the battery.
Old 01-29-2017 | 02:46 PM
smitty901's Avatar
smitty901
Received 10,401 Likes on 5,516 Posts
Pick up a $1 light switch at ace wire it in it will work.
Old 01-30-2017 | 04:14 AM
damquick1's Avatar
damquick1
just my $.02......don't go cheap on a nice scooter.....too much trouble in the end...do it right the 1st time and never have to re-do-it
Old 01-30-2017 | 12:23 PM
Lunchboxx's Avatar
Lunchboxx
I wired LED light on the front of my RG tothe stock accesorie switch. I bought a premade wriingt harness fromamazon the included a switch and relay. I ran the wiring along side all the stock wiring under the tank and into the fairing. I used my manual and found the acc. switch wires and used one of those crimp on wire connectors to the switch leg(from Acc. Sw.) and then used only the switch leg on the provided wiring harnes and plug it into the connector I installed. Presto we have light that work with the acc. switch.
Old 01-30-2017 | 01:15 PM
Blue Tick's Avatar
Blue Tick
Do you have any pics and part numbers by chance? I will be installing a total of 8 led strobes on this bike and want them to work off of a master switch that has it's on relay and fuse.
Old 01-30-2017 | 01:40 PM
Drifter-10's Avatar
Drifter-10
J&C Cycles sells a Double Rocker Switch that replaces the standard accessory switch on the bike. I have used one before with no problems and have one ready to go on my bike now whenever I get ready to do a couple of more mods.
Hope it helps
Old 01-30-2017 | 01:43 PM
davidwruth's Avatar
davidwruth
71400044 switch from HD is 13 bucks
Quick Reply: Accessory Switch
