Length of toe/heel shift lever extended reach
My heel shifter is about 1" shorter than the floorboard and I want to change the heel shift lever to the extended reach part - p/n 33600001.
Although the catalog shows that the extended reach lever is 1" longer than the standard, the problem is that HD does not publish the actual length of either one. So I don't know which one I actually have. I cannot tell by the picture in the catalog.
Does anyone know (or can measure if you know which one you have) the actual length of either one?
Thanks,
Mike
Thanks,
Mike
usmcvet0331 (08-29-2024)
usmcvet0331 (09-03-2024)
I added the Harley extended shift levers for both the heel & the toe shifters the are 1 inch longer.
Part #33600001---There wasn't enough room for my fat feet.
If you need more room go to www.waltersworkshop.com
Walter has a 2 inch extended shift lever, that looks like a stock lever but is 2 inches longer.
