Anti-Seize on Muffler Joint?
Old 01-21-2017 | 08:03 PM
ejvette's Avatar
ejvette
Default Anti-Seize on Muffler Joint?
Just curious I pulled my slip-ons off today and as you might guess with a bit of rust they were quite difficult to remove I was wondering if its ok to put a bit of anti-seize compound on the joint ?
Old 01-21-2017 | 08:08 PM
mkguitar's Avatar
mkguitar
I have
go as light on the clamps as you can and still get a seal
mike
torchmaster's Avatar
torchmaster
You'll want to use copper anti seize for high temp applications. The regular stuff will just burn off and make a lot of smoke.
The following 2 users liked this post by torchmaster:
1HD1C (01-22-2017), SpiderPig (01-22-2017)
Old 01-21-2017 | 10:25 PM
wscott's Avatar
wscott
Yes,i have used anti-seize on slipon joint's on my HD with great results when removing the mufflers @ a later date.
Scott
Old 01-22-2017 | 02:33 AM
Peter Griffin's Avatar
Peter Griffin
I have with good results
Old 01-22-2017 | 05:31 AM
1HD1C's Avatar
1HD1C
THIS!!!! its exactly what I use on every bike I have installed pipes on
Old 01-22-2017 | 06:36 AM
ejvette's Avatar
ejvette
Thanks guys!
Old 01-22-2017 | 08:40 AM
2goldens's Avatar
2goldens
Scott
Same here. More than once.
Old 01-22-2017 | 09:16 AM
todd-67's Avatar
todd-67
I have used on my last 3 harleys. If you don't it can be a real pita to get the mufflers off.
Old 01-22-2017 | 03:21 PM
ejvette's Avatar
ejvette
I ordered a can of permatex copper from amazon.
Quick Reply: Anti-Seize on Muffler Joint?
