Installed them today and the left side bag doesn’t close all the way, there’s a gap.
Ive messaged them and I’m waiting for a response, minor QC issue.
I’ll try to attach a pic, I put a flashlight on the inside to illuminate the gap.
i used my stock lids and hardware on the extended bags and everything fit perfect
Talked with them this morning and asked specifically about the standard fmotos or nastyhog lights and she said they are about 2X brighter and solves the problem. I ordered a set and will report back after I put them on
Have you got the Top Shop LED’s installed yet? I’m just curious how much of a difference they are?
I got the topshop lights and look very different from the fmotos (nasty hogs product is fmotos). Unfortunately, the four letter word (work) got in the way and I had to travel so I haven’t put them on. When I do I will update here first.
Have ya installed these yet??!! I’m waiting to pull the trigger on these, want to be sure they fit the same and perform better!!! You’re killing me with anticipation hahah!!
I bought the Top Shop lights a couple weeks ago. You have to use their wiring harness. If you do not their lights will not work correctly. In my opinion however they are barely brighter than the lights that come with the Nastyhog fenders. Also the Top Shop lights do not have much difference in brightness between the running lights and the brake/turn signal lights compared to the Nastyhog lights which do. I would not recommend them.
Why wouldn’t the NastyHog’s harness work? Looks like the TopShop lights use the same Duetch connectors, are they pinned differently?
