08 StreetGlide Front Brake Lock-up
I experienced a front brake lever lock-up as I was pulling off the freeway. It was very alarming (and dangerous) since I frequent my front brakes and I could not suppress the lever. The rear brakes worked ok so I was able to avoid any issues. I have read some past threads about similar problems but didn't see any remedies.
Is it possible to eliminate the front brake ABS only and keep rear brake ABS?
Thanks
Thanks
Just casually reading through the forums suggests that ABS and factory security generate far more headaches for owners than any other individual systems. Definitely makes me glad I have neither system on my sled.
Security seems to me down to owners mostly, especially those who buy a secondhand bike and either don't get the owners manual or don't read it. For recent bikes they are available on-line via the Owners tab on the H-D website. ABS is more serious, for obvious reasons, even more so if the bike is out of warranty.
Either replace the ABS unit and start "fresh" or plumb around it with BOTH brakes. These are the only choices which provide confidence in a very critical system.
If you have the malfunction, tell the NTSB. No matter how many of these units Harley replaces, I doubt they will "tattle" on themselves to the NTSB. In my humble opinion, this should be a safety recall for a faulty system.
Thx btsom
I agree with your thoughts and have decided to convert both brake lines to non-ABS because of that one comment "TWICE". I surely don't want that *** tightening white knuckle brake failure again. I rode all weekend and I have to admit it was nice not feeling those rear brakes "let go" on the dirt roads that ABS causes. Thanks Bro
D W K (01-17-2017)
I believe some of the ABS problems may result from not replacing brake fluid at least every 2 years. Probably crud gets in the ABS causing malfunctions. While expensive to replace the module, if you can swing the costs I would do it as ABS can and is a lifesaver on the road. The ABS can prevent the bike from high siding since it generally does not allow the tires to slide, unlike standard brakes. ABS is one of the best things to happen to motorcycles, when it's working that is.
Received 4,763 Likes
rakanghoth
12-02-2008 02:27 AM
