Left side exhaust sqeaks again
Looking for some help here. The left side muffer (Hooker) sqweeeeeeks again. The header pipe was cracked and HD replaced it some time ago,the noise was gone, now after a tire replacement the noise is back but theheader is solid. There is some movement at the rubberbushing near the rear of the muffer. Any suggestions??
Guest
Posts: n/a
Sounds like a good reason to go to a 2-1 exhaust..... just a joke.
Try working some white grease into the rubber muffler hanger on the saddlebag support tube. I bet that's where the squeak is coming from. If that's not it, it could be a heat shield ever so slightly loose. I had one that drove me nuts.
I had the same problem after I replaced the pipes on my '03 RKC, except it was the right side. It happened most often when it was hot out, and it was worse at lower RPM's (scared the neighborhood kids and dogs when I was idling down the street!).
I sprayed some silicone spray on the rubber hanger below the saddlebag -- and that took care of it every time. Ended up keeping a can of the silicone in my bag so I could spray it as soon as it started to squeak.
![Lightbulb](https://www.hdforums.com/forum/images/icons/icon3.gif)
For $4.00 you can buy a set of those rubber bushings from H-D (it's an item they all have on hand) and even the most inept idiot with a 1/2" socket can swap those out in 15 minutes, solving the problem. As an inept idiot (who once stripped his oil pan drain screw because he didn't understand how a torque wrench worked) I can vouch for this fact.
Remove saddle bags (if applicable) to access the hangers. Tie the rear of the pipe up to your signal / plate mounts or put something underneath them so that they are not "freeballing" once you remove the hanger. Using a 1/2" socket, remove the bolts. Slide the chrome plate out of the bushing. Take a screwdriver and push down on the front top of the bushing while pushing it through. Clean off the gunk, slide in the new bushing from the front, plate back in, tighten bolts. Done and Done. QUIET. Sweet relief....
I lived with this problem for YEARS before I found out how easy it is to get rid of it. Let the world know - it's spring again and my birds have stopped chirping. Halla-freakin-luya !
I to went through all of sqeaky pipe solutions on my Road King. Then, with the pipes hot and wearing a pair of welding gloves I pulled and pushed on the cross over. Ah ha the squeak. While dismantling, discovered the pipe hanger mount, allan head bolts at the engine were loose. (damm stealer had their hands in there a month back) dressed the screws and torgued them down. Problem solved. No issues since, whew very anoying
