Stock Internally Wired Bars?
the throttle has been by wire on touring models since 2008.
on the 2017 RK, the switch wiring ( start, kill, turns, high beam and horn) are external- the fewer switches and canbus electrical system allow for a slimmer wiring harness, but it is external to the bars- as are brake and clutch lines
a model with radio controls on the bars, intercom or cruise would have twice as much wiring
on abs models you will see brake lines on the rt side of the neck in front of the tank.
mike
mike
Received 1,639 Likes
Me thinks when HD reprised the RG/RGS in 2015, they had all internally wired bars. You'll find only the clutch and brake lines are outside. The first to do so in the touring line sans the CVO, if I'm not mistaken. Just like the Fat Boy is in the Softails.
The '17 gold and black King I saw at the dealer last week had the wires outside the bars.
