Road King Headlight Nacelle
it'll be same for all 2014+ models
you can find a parts diagram here:
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
don;t forget a thick towel on the fender!
mike
mike
It's been awhile since I've had mine off but if it's the same as my 08, start by prying off the trim ring around the key hole for the fork lock. A knife or a thin bladed screw driver will work great. It just lifts out. That will expose the screws that hold down the fork clamp cover, which will expose the screw for the chrome strip down the top. There is a screw at the bottom of the headlight that will remove the headlight trim ring. Then you can see how the main piece comes off from there.
paullavery (12-28-2016)
https://www.hdforums.com/forum/touri...road-king.html
