Ignition Lock Help Please
check the videos on youtube for an overview of the problem
the solution is to either not turn the bars or to use an alignment tool such as squarshed 1/4" copper tubing... too late for that now
this is common and we have all done it once or twice
if you look at the knobbys on the ignition stem, you will see that they are not shaped the same- look into the cavity and you'll see if your switch cams need to be turned, you can turn one at a time to align with a screwdriver
you may want to pull your maxi fuse while you do this
mike
mike
Their is a service tool to assist with this
like mkguitar said it can be done with something to align everything just be patient there should be something in the service manual I know there was when I had my sons road glide apart for front end work
Had the same problem recently. Found the answer here on forums. This place is the greatest.
All you need is a medium to large straight blade screwdriver and a flashlight. Look down in there, use screwdriver to realign and insert ignition switch. Took me two tries to get lined up. No need for any special tools.
Bigwillie
08-24-2010 11:12 AM
