Multiple electric horn
Not to start a controversy about which horns are louder or better but I plan on installing the Fiamm highway blaster horns (low tone and high tone). My question is do I need a relay or can I just splice the wires together and run them to the stock horn wiring?
I did a search and found different opinions, so not sure. My guess is I don't need a relay because the horns are electric and don't draw many amps as oppose to an air horn. I hope to run the stock horn and the two Fiamm horns. Not sure if I'll attach the Fiamms to the front mounting bolt of the gas tank or somewhere off the front frame.
Thanks
Thanks
I would suggest a relay- it is easy, removes high current loads from the stock wiring ( whether "old" analog wiring or 14+ canbus) and provides full power to the horns.
I do use an airhorn ( H-D, got it cheap from a member, used. tried a howards air horn...it failed in weeks. on my FXR I use a 6 volt horn...plenty loud and it's been on for about 10 years...it's not like I lay on it- cost about $15 on ebay
Mike
Mike
Received 2,530 Likes
No relay here, I just tapped onto the cowbell horn and ran it to the two new horns. Plenty loud. Mounted facing front off the front fuel tank tab mounts, tilted slightly down for water to run out of them. High note, low note, stock horn together sound like an old Cadillac Fleetwood. Great safety addition.
a Fleetwood adds a 3rd horn, a lower F to make a F Major chord...
i got plenty of both kinds horns and cadillacs...fleetwoods
since I work in music i use strobe tuners to set up horns for collectors...I can make a sour horn sweet
mike
a Cadillac will play a low C and a high F making a "C for Cadillac" chord
mike
mike
What I like is the look on their faces when others pull up to a stop and don't look at me - so I blare 'em at em, and they snap that head around and give me the wide eyed look.
It is an attention getter!
mike
mike
i have the low/high fiamm horns on my bike. No stock horn. I did not use a relay. I like they are loud when used, but i do not use them enough to justify the cost of the relay. if the horn switch burns out or gets damaged, i might change my set up. So far, they have worked for 3 years with no problems. I have them mounted off the gas tank tabs so the water will drain out.
I have had this arrangement for a coup of years; added a relay the first time I almost got pushed into a concrete barrier and blew the stock horn fuse.
Two older (than me) farts gabbing like a couple of bitches on I-4 in the right lane decided to change lanes without looking, signaling or giving a **** that I was right next to them in the left lane.
I laid on that hat horn for all it was worth, and it worked like a charm; both of them probably **** themselves at least a little!
Once I reached my destination I was so proud of my horns I decided to give them a toot for the hell of it; they were both dead!
when I got home I added a separate circuit off the battery through a relay that was controlled by the stock circuit. No more problems no matter how long I hold the horn button for.
Definitely one of the best mods that I've done at a cost of less than $25.00.
