Need led help
Old 12-13-2016 | 08:42 AM
Electraglider51's Avatar
Electraglider51
6th Gear
Default Need led help
Hi gang,
2012 electra glide ultra limited. I'm converting all the lights to led. Got plug n play panels for the blinkers. Also got a plug n play load manager. Installed everything and now my blinker indicators on the dash light up solid. When I hit the blinkers all four flash. I'm also getting dim light on the rears when they're supposed to be off. I have 1157 amber panels for the front and 1156 red panels for the rear. I plugged the load manager into the harness for the rear lights. Am I missing something? Need some advice please. Mike
Old 12-13-2016 | 09:08 AM
DamifIknow's Avatar
DamifIknow
Sorry I dont have any answers. Custom Dynamics? Call them. I'm gonna buy same set up for my 12 limited soon
Old 12-13-2016 | 11:35 AM
JMC22's Avatar
JMC22
What happens when you put the stock non-LED bulbs back in?
What company did you get the LED's from?
Old 12-13-2016 | 12:14 PM
jeeper101's Avatar
jeeper101
Which brand? I know custom dynamics load equalizer is supposed to work on bikes 13 and down but some special editions don't require the LE for some reason. Perhaps this is your case?
Contact the manufacturer and try to get an answer from them.
I would try removing the LE just for laughs and see if that makes the issue go away...
Old 12-13-2016 | 12:42 PM
Electraglider51
6th Gear
If I remove what I installed everything goes back to normal. If I remove the LE I still have the same problems but **** just blinks faster! Lol. I'm not sure what brand I have for the lights. Got them off fleabay
No idea what brand lights I have. Got them off fleabay. If I remove the LE I still have the same problems but **** just blinks faster.
Old 12-13-2016 | 01:14 PM
DamifIknow's Avatar
DamifIknow
Thats why I wont buy LEDs from eBay. Heard bad things about headlights and tail lights.
Old 12-13-2016 | 09:02 PM
jeeper101's Avatar
jeeper101
Brushing my teeth while reading this and I literally just spat toothpaste all over the sink!!!!!! That was a funny post.
Electraglider51 (12-19-2016)
Old 12-19-2016 | 11:31 AM
Electraglider51
6th Gear
Ok guys, found the problem.(I hope) it seems the load manager is either defective or not the right one for my bike. I contacted the seller and he's sending me another one to try. Now I didn't explain this part. With the LM unplugged, when I hit the blinkers button I get 3 normal speed flashes then it goes into rapid flash. Should I be looking for an led flasher instead of a load manager? Do I need both? I have a feeling the replacement load manager is going to produce the same results. Mike
Well I was right. The new equalizer arrived today. Plugged it in and have the same problem. Now what?
Old 12-24-2016 | 10:22 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I had the same thing on my Blackline...the "dash" light would flash fast but the lights themselves would flash at a normal speed. I just ignored it.
Are your turn lights flashing fast or just the dash light or both? Personally, as long as it's flashing, I'd be okay with it.
Old 12-24-2016 | 10:30 AM
Electraglider51
6th Gear
Both lights flash. I've finally figured out there's a problem in the front blinker panels. Must be made wrong or something. Taiwanese ****. I can make them blink, I can make them running lights. Can't make them do both. Going to buy another set of front blinkers. I've spent 4 days on this fu@#ing issue. Thanks to all those who responded. Merry Christmas
EdandGrace
2014-2023 Touring Models
27
11-14-2015 10:48 PM
NVERL8
03-24-2014 05:31 PM
griggi63
05-31-2011 10:54 PM
BohicaAZ
01-07-2011 07:17 PM
powdercoater
10-22-2007 01:24 PM
Quick Reply: Need led help
