Is there anyway to tell the CB and the AM/FM antenna apart ??
Old 12-06-2016 | 05:37 PM
HDJIM1158's Avatar
HDJIM1158
Default Is there anyway to tell the CB and the AM/FM antenna apart ??
Is there anyway to tell the CB and the AM/FM antenna apart ??? There is a little clock type mark on the bottom but there are no other marking on them. Thanks in advance for your thoughts
Be Safe JIM
Old 12-06-2016 | 06:31 PM
14GuineaPig's Avatar
14GuineaPig
The base of the CB antenna is marked CB
Old 12-06-2016 | 06:33 PM
cmc seabee's Avatar
cmc seabee
Look on the bottom of the antenna 180 degrees from where the clock mark is, and one antenna will be marked AM/FM & the other one will be marked CB.
To keep from mixing up the antennas when installing them I took some of my wife's red fingernail polish and put a red dot on the CB antenna at the bottom.
I always remember red is right side.
Hope this helps. Have a great holiday season.
HDJIM1158 (12-06-2016)
Old 12-06-2016 | 07:19 PM
skyflyer's Avatar
skyflyer
C.B is a little taller.
Old 12-06-2016 | 07:32 PM
lh4x4's Avatar
lh4x4
All mine have been stamped in the rubber base. Need to look real close.
Old 12-06-2016 | 07:37 PM
leon anthony's Avatar
leon anthony
just go to the dealer and buy a cb antenna and put it on the left side the they will both be c b antenna and you wont have to worry about it any longer
Old 12-06-2016 | 07:39 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The red dot is a good idea, might do that myself. Except I'll put the red on left side of the bike.
Old 12-06-2016 | 08:21 PM
Cobra1's Avatar
Cobra1
Yes red, left, port. All of the short words go together.
Old 12-06-2016 | 10:03 PM
HDJIM1158's Avatar
HDJIM1158
Thanks, there it is, never noted it before....This is the best groups of riders out there.
Be Safe JIM
Old 12-07-2016 | 06:21 AM
ohioflhs's Avatar
ohioflhs
Why not remove one and see which component doesn't work anymore?
Quick Reply: Is there anyway to tell the CB and the AM/FM antenna apart ??
