Brake/Shifting Controls
Old 05-29-2007 | 10:28 AM
Rob2002's Avatar
Rob2002
Default RE: Brake/Shifting Controls
This helped a bit.
Got the floorboard extensions from Soos and I think it made it just a bit better.
Don't have to move quite as far out to get around the brake and shifter.
3/4" helps.
Old 05-29-2007 | 10:32 AM
Cannon00000's Avatar
Cannon00000
Im expecting my EZ brake and shifter to arrive today. Hopefully this will solve the the same problem I have. I am 6'2 and find the controls on my RK to be to short as well. I'll let you know once I get them installed what type of a differnece it makes. I also am thinking about buying the HD extension floor boards.
Old 05-29-2007 | 10:51 AM
the_icemAN's Avatar
the_icemAN
if you need longer shifters .... look also at softbrake:
http://softbrake.com/
They have shifters etc there. You can get multiple sized extensions for your shifter arms ... also have extended brake levers as well. Nice outfit.....
Old 05-29-2007 | 05:13 PM
iclick's Avatar
iclick
ORIGINAL: curmudgeon
Spend the $200 on the fancy linkage. I know it's too much money, but the stock one is going to break and leave you stranded so you might as well spend the money now. Go ahead, you're worth it!
You can buy heim joints to replace the crummy stock ball-and-socket units for $20/pair on Ebay, also available from CC or Drag. There are also some nice billet-chrome rods with heim joints on Ebay for <$60.
Old 05-29-2007 | 05:55 PM
Papamte's Avatar
Papamte
Definately go with the helm joints. My forward ball/socket joint broke sat and I had to use tiewraps to hold it together to get home.
Old 05-30-2007 | 10:00 AM
leond's Avatar
leond
I have an EZ Brake on my Electra Classic. It gave me much more useable space on my floorboard.
I still can't get my foot under the brake however so my foot angles outward. Is there someone that make a brake pedal that's not as wide as the HD or EZ brake pedal?
LeonD
Old 05-30-2007 | 01:24 PM
Cannon00000
Beancount- I thought the Mustang seat moved you back??
arod6
11-14-2015 03:55 PM
ss243b
08-22-2014 07:08 PM
h-d wrencher
07-05-2012 11:25 AM
budzilla
04-01-2008 02:00 PM
ShoreRider
11-16-2007 06:45 PM
Quick Reply: Brake/Shifting Controls
