Yet more cam confusion
If you don't already have the cam's then why don't you do the build in my signature? It's a 103" with Woods 777's set at 10.6 comp. with head work, but if no head work I'd drop the comp. down to 10.3 and install a Andrews 57 cam.
I may get flamed but there is better cams out there imo than the 570's, sorry.
Thanks for the feedback, and it would seem that you think otherwise
You are in the same position I was except I have a 107 big bore already installed. I wanted to get more low end torque but also not give up on HP on the higher end. I researched for awhile looking for the right cam/head work combo and ended up with head work (oversize valves, porting, and milling) with the T-Man 590 cams.
I looked at Woods cams (555 & 777) and also Zippers 575, T-Man 555 torqster, and regular T-Man 555. The regular 555 maybe a good bolt-in for that 103 at that compression. Call T-Man and talk to TR, he talked to me for sometime not even knowing if I was going to go with his cams.
Set up with the right compression, good flowing heads, and a good 2-1 pipe the woods 777's will perform great in a bagger. I'm running them in my Ultra and have 100tq at 2250 rpms. They will pull to redline as well.
I've put over 10, 000 miles if not more on this build and I ride the back rds of east tn as well as Nc, blueridge pky and such and this thing has bottom end like crazy. Take a look at my dyno chart in the dyno section for this build, I couldn't be happier! Its post #5298
Look at Longridertx's post. It all needs to work together. Cams, pipes, compression, etc.
777s require more compression to get the most value from them.
Like I said, call a reputable builder, they will help you.
Here's the chart for my 107 with 777s. Not high RPM in the least, but with more compression, etc.
777's are not "high RPM skewed".
