Silly Question
Silly Question
I've got my bike put away for the winter ( 2014 FLHTK ) or I'd check it myself. I was wondering if either the accessory plug in the fairing, or the one in the trunk was hot all the time so you wouldn't have to turn the switch to accessories, thus turning on some of the running lights, to charge something.
Thanks Jonnierock
Thanks Jonnierock
or you can attach to the tender plug- deltran now makes an adapter for the tender pigtail which has a usb 5 volt out.
https://www.amazon.com/Battery-Tende.../dp/B00DJ5KEF4
the tender pigtail is connected straight to the battery- on most there is a fuse inline..3A I think
Loading down your battery while stored isn;t a good idea.
I'd disconnect the battery and if your area is cold, take inside on the bench
mike
mike
He's not talking about tenders or keeping the battery charged...
I know where he's coming from though. Been a few times my phone was near dead and I was camping.
Wished I could charge it with the bike but that requires having the bike "on/acc". A hot lead just for charging etc would be nice. I know you can wire one. May do that.
bradsULtd (11-29-2016)
Received 4,806 Likes
It has to be, in order for the battery tender to work.
As mkguitar mentioned, if the OP wants to charge a phone or similar without having the ignition on, get one of those SAE to USB port charging adapters he linked too.
