Handle Bar alignment?
Old 11-12-2016 | 05:02 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Originally Posted by Buelligan666
Sure your arms are the same length?
Do you have poly bushings or the stock rubber ones? I'm guessing it's in the bushings.
I used to work with a dude that wore His hat cocked way over to one side. Looked weird. Strangest thing I ever saw.
Then one day, someone pointed out the obvious - the hat was level and straight - it was the dude that was crooked! Physically and mentally!
Oh well, good luck with the alignment thing...
RiverB (11-12-2016)
Old 11-12-2016 | 05:04 PM
skratch's Avatar
skratch
Originally Posted by Tarkus60
Mine has a 2 piece top clamp. So going with a 1 piece I would loose the top part of the nacelle???
no, the top clamp would still be covered, just as it is now. the cover would still fit over it.
Old 11-12-2016 | 09:58 PM
wide glider's Avatar
wide glider
I can sorta see a slight twist to the right of your bars compared to the top tree. They ALL do that....seriously. Not a dealers line they do twist on the rubber bushings (the risers that is) and even picking up the bike and setting it back on the side stand puts a twisting torque on the bars and risers in the right hand direction. Harleys are heavy bikes and the bars move due to the stock rubber bushings. Not a big deal just something we live with. Correct it if you choose but it will twist again in short time. It was really noticeable on my softail with 6in night train risers and drag bars. I fixed it a few times but it always came back. No big deal. I'd rather ride than wrench.
Chase D
12-25-2018 12:21 PM
Gibler77
Milwaukee Eight (M8)
04-17-2017 06:30 PM
TwoBlue02
08-03-2012 09:17 PM
rrambo
04-27-2011 09:32 AM
paul_scooter
08-15-2006 11:51 PM
Quick Reply: Handle Bar alignment?
