Tour Pak: Cable broke, hinges bent...
Just a gripe - and maybe advice if anyone has a different solution. Yesterday afternoon while putting my helmet in the Tour Pak the retractable tether on my '09 Ultra broke, the lid fell to the side, and now the lid won't close properly. Its not lining up so the latches wont work. I think the hinges are bent. I assume my only option is to replace them at this point. I guess it could have been a lot worse as it easily could have cracked the box or lid.
Sorry to hear it. I use this so that it doesnt happen to me. Expensive, but worth it!
http://www.eglidegoodies.com/id40.html
The following 2 users liked this post by Keithhu:
ElectraJim (11-01-2016),
vistavette (11-01-2016)
The following 2 users liked this post by Boomer1143:
leadman (11-01-2016),
... you're quite lucky that the ABS around the hinges did not crack.
........ i'd just drill out the pop rivets on the old hinges & install the newer 'premium' hinge set that HD sells.
..... i'm thinkin' i'll stick with the remarkably lo-tech cable that holds my lid when opened.
Yeah - I just got back from the dealer and picked up a set of the Premium hinges. I know they'll look great I just didn't want to bother...but of course more chrome is never a bad thing.
...... it's quite remarkable how often there are posts about this having happened.
Not sure if this is the right bike, but the hinges can be found here:
http://partsfinder.onlinemicrofiche....AK%20-%20COVER
Edit: Never Mind. I just read you already bought others.
Hmmm.... now you have me thinking about this. Thanks for the post!!
