Move O2 Sensors?
the older o2 sensors are located nearer the heads as they need the heat to activate- they don;t work below about 600ºF.
the newer models ( 2010+) use a heated o2 sensor- which came in with the cat in the header for all versions
( yes, some 2009 models had cats, but they were higher up the header tube).
o2 sensors supply voltage in realtime to the ecm--- if you are running at 3000 rpms, the ecm is pulling data 750 times a minute from each of the o2 sensors and altering fuel delivery based on the voltage.
poor data may result from a poorly designed exhaust system which allows the pulses of exhaust gasses to moving back and forth within the exhaust tract, and/or exhaust gasses to eddy or even reverse course
( this can happen with a perf core baffle with the packing removed- or any exhaust tract in which the velocity drops, like if a 2" passage suddenly becomes 3" or larger)
so I would guess that if you have a well designed exhaust system which good controlled flow you would be running well- and moving the sensors wouldn;t do much
if your exhaust is a random put together with poor flow characteristics you may get an improvement moving the o2 sensors- It is possible that the heat produced closer to the exhaust will work against them.
but you'd likely get an even better result with a designed exhaust system with calculated flow and predictable results.
if you have smooth predictable motor operation at all throttle positions and transitions, I'd say you are doing fine
Mike
Mike
Mike
Mike
I may just try an auto tune after running my canned map for some time to see how it works out. Im in play mode with a new toy.
Well the FP3 with canned map of Twin Slash Rounds w Power Duals (recommended by V&H to be similar to Rush Big Louies with Decat header) is running nice so I may not change much at this time. It has solved my pinging on inclines and occasional decel pops. I will likely run auto tunes at some point but likely not til spring when can ring it out good. Maybe a winter project to prep another pipe and add some bungs farther up the pipe but not too close to the exhaust ports.
WildBill2566
09-27-2011 10:15 PM
