Mounting Control for heated gear. Ideas ?
Old 11-01-2016 | 03:26 AM
Tanuki's Avatar
Tanuki
Default Mounting Control for heated gear. Ideas ?
How or where do you guys with touring bikes mount your control ( Heat Controller ) for heated gear to your bike ?
I used to clip the control to the leather tank panel on my Dyna but the Roadking has a metal dash so not so easy to mount.
Thinking of fabricating a alloy or stainless bracket mounted from under the seat area some where that sticks out near the seat to clip the control to. Looking for ideas.
Old 11-01-2016 | 05:24 AM
foxtrapper's Avatar
foxtrapper
Veteran: NavyVeteran: National Guard
In my pocket.
Old 11-01-2016 | 07:10 AM
ghostrunner's Avatar
ghostrunner
Plugin for the gear drilled hole and mounted the plug in the mid frame heat shield on left side and keep controller in pocket.
Old 11-01-2016 | 07:24 AM
TcHunter's Avatar
TcHunter
Do you already have the controller? if not i use a dual wirless one, works great only one wire to plug in and with-in reach for any adjustments...
The following 2 users liked this post by TcHunter:
Qdog002 (11-04-2016), RiverB (11-01-2016)
Old 11-01-2016 | 07:57 AM
Tanuki's Avatar
Tanuki
Yes i have a dual controller. Looking for a better option than in the pocket with wires hanging out.
Old 11-01-2016 | 08:11 AM
Tanuki's Avatar
Tanuki
Ok just read about Gyde by gerbing 12V wireless dual controller , that seems to be the perfect thing im needing. Guess it will work with the harley gear too.
Old 11-01-2016 | 08:23 AM
SeeJeepCrawl's Avatar
SeeJeepCrawl
I got this controller from warmnsafe and thought about running a ziptie around it, then using velcro stripping to go between the ziptie and the unit and attach to the saddlebag guard in front of the saddlebag, near the seat.
My initial thought was to place near the handlebars, but the cabling is not long enough. I really don't want to drill holes in the air deflectors, and the guy at warmnsafe said don't keep it in your pocket.
Any other thoughts would be great. (Hope you don't consider this hijacking the thread).
Old 11-01-2016 | 10:43 AM
TcHunter's Avatar
TcHunter
If you could pick up a used side cover to use during the colder months you could drill it out and mount your contoller on the inside, have the two ***** sticking out the side/top, wires are out of the way and you could make adjustments on the fly.....
Old 11-01-2016 | 11:38 AM
DanHappy's Avatar
DanHappy
Why dont you just extend the wires. Add some in between.
Old 11-01-2016 | 11:44 AM
Captain Itch's Avatar
Captain Itch
Sponsor
We make a gadget panel for this controller .. check out this link http://shop.captain-itch.com/Magneti...Tank-Panel.htm
__________________
www.Captain-Itch.com
shekmark (01-14-2017)
Quick Reply: Mounting Control for heated gear. Ideas ?
