07' Road King front wheel??
Old 10-28-2016 | 07:30 AM
TowerDawg's Avatar
TowerDawg
Default 07' Road King front wheel??
Looking at new wheels and want to know if anyone can tell me what size wheel and tire combos will fit with stock fenders and rake. Pictures are a plus.
Old 10-28-2016 | 10:04 PM
RollTideRoadGlide's Avatar
RollTideRoadGlide
Stock fender you can only go with a 21in wheel, and its a tight fit. I had to drill out my mounting holes for mine to fit correctly.
Old 10-30-2016 | 12:44 PM
grbrown's Avatar
grbrown
All stock wheels Harley has used, from 16" to 19", have similar rolling diameters, only larger wheels than those sizes need any changes to accommodate them. What have you in mind?
Old 10-30-2016 | 04:30 PM
TowerDawg's Avatar
TowerDawg
im looking at fat 50 spoke wheels. I've found mostly 21". I've seen many threads about 21's fitting with stock fenders with the 120/70 tires. But at the same time I've seen a few where the fit didn't work. Some say it was the quality and compound is older tires that was the issue.
I did find a fender lift bracket. Still looking into those.
This is all part of a many step process to customize my bike for me. A matching rear wheel would be down the line.
Old 10-30-2016 | 06:26 PM
patriot2500's Avatar
patriot2500
I had a fender lift bracket installed when I put a 21" on my bike. It looked awesome and rode great, but I had some issues with my front end bottoming out on my fender due to lack of oil and shot springs. I decided to take the fender lift and 21" off, reinstall the stock wheel, and wound up trading the wheel for a brand new seat and some cash, so I'm happy with it. Bottom line is make sure you check your front springs and fork oil when you do this. Best of luck!
Old 10-30-2016 | 09:54 PM
Atat75's Avatar
Atat75
Stage III
Patriot Was your front end lowered? I have a 15 RK and put a 21 inch rim in the front but haven't put the risers on my fender yet for fear of bottoming out! Most people have said as long as I go with heavy fork oil and leave the stock height I should be fine
Old 10-31-2016 | 01:46 AM
RKZen's Avatar
RKZen
I have 21" fat spoke front wheel on my King and modified the fender mounting holes slightly to move the fender a smidge for clearance. Bike is lowered as well. No issues here with monotubes.
If you want a smaller front wheel, many come in 16 and 18 also, and some in a 17 and 19.
Old 10-31-2016 | 07:16 AM
TowerDawg's Avatar
TowerDawg
I've heard of the mod you speak of. Nothing more than enlarging the existing holes 1-2 drill sizes.
As as far as wheel size. I like the look of the 21. I feel there is still enough meat on the tire. I don't want too thin of a rubber.
Old 10-31-2016 | 07:54 AM
patriot2500
No sir all stock front end. Heavy fork oil a must in my opinion especially if you do the fender lift.
Old 10-31-2016 | 08:01 AM
bikerlaw's Avatar
bikerlaw
MOST people can bolt on a 120 21 and be OK. But drilling out the rear mounting holes, and raising the fender is cheap insurance should there be a problem, such as a slow leak causing tire growth at speed. But a 21 is a very common mod and most of the HDFORUMS vendors are happy to talk to you.
Quick Reply: 07' Road King front wheel??
