Aux Switch 09 Ultra
Are you referring to the Aux switch or the ACC switch?
The Aux switch is the far right position on your ignition switch. With the ignition in the Aux position you can turn on the radio, turn on the Passing Lamps, operate your turn signals/brake lights. It will also send power to the ACC switch on your lower inner fairing.
The ACC switch powers the accessory plug that located under your seat.
