Torque Wrench
I had been using one from Harbor Freight and one day I decided to check it against my neighbors digital SnapOn torque wrench and discovered the HF wrench was over tightening things by a ton. Not saying all Harbor Freight stuff is bad I own a lot of it but good to check the accuracy of whatever wrench you are using.
I always put Teflon tape on my drain plugs. No, I don't use a torque wrench on them. I do use a torque wrench for nearly everything else, especially engine components. I have never lost a plug nor have I twisted the threads out of a case. Maybe experience has a few rewards, or is it blind luck?
I'll say this: If you rely on a torque wrench to tell you when to stop turning, you're a disaster waiting to happen. I've had HF, Craftsman, Snap on and MAC... they've all tried to F^2% me at one point or time. The last time I let a MAC torque wrench screw me was when I was working on the case halves of a Lycoming Aircraft engine, while the engine was still in the plane. I'll never do that again. So, Now... I torque to MY specifications and then back up with the torque wrench. If it don't click with in 1/4 of a turn my arm specifications, then theres a real chance something is wrong with the bolt or threads already.
so... I vote... snug using your own hand and follow up with a wrench.
Um.... doesn't an oil plug have dissimilar metals (aluminum case, steel plug) and a rubber seal (o-ring).....?
Why the double standard for an oil plug.... just curious.......
