What is this?
05-26-2007 | 06:47 PM
RE: What is this?
maybe a better picture
[IMG]local://upfiles/22412/11D776C5AE014BAFB0DF5DB02AF47D8A.jpg[/IMG]
that and it is zip tied to a spot on the frame right where it is. I don't it will go under the side cover.
05-26-2007 | 07:17 PM
RE: What is this?
accessory plug
05-26-2007 | 07:28 PM
RE: What is this?
battery tender plug, pull off seat and see if it is hooked up to battery.
05-26-2007 | 07:31 PM
RE: What is this?
Battery tender plug.
05-26-2007 | 07:47 PM
RE: What is this?
looks like my battery tender plug
05-26-2007 | 07:50 PM
RE: What is this?
It's a Battery Tender Plug... Most dealers install them @ delivery & hopes you buy the tender that goes with it...
05-26-2007 | 07:54 PM
RE: What is this?
battery tender plug. put a dab of electrical grease onto the contacts then cover back up again so it will be ready and free of corrosion when you get the battery tender to plug into it.
05-26-2007 | 07:56 PM
RE: What is this?
WHOOOAA NELLIEEEE....it is not,repeat NOT your battery tender plug..unless you yourself installed it.. it IS the Accessory plug which is for things like heated seats...vests..et. if you want a tender plug you have to buy one and install it..trust me..I have both on my bike...
05-26-2007 | 08:00 PM
RE: What is this?
If it only has 2 pis it is a battery tender, more than that and smaller would be the ecm module test leads ..Mark...
05-26-2007 | 08:16 PM
RE: What is this?
HERE is what a battery tender plug looks like.
You can plug that accessory plug into a battery tender if you want to, but your battery will still be dead when your through.[sm=icon_rofl.gif]
[sm=icon_rtfm.gif]
