I loosened the line only to adjust. However, it looks as though I lost some fluid and most likely got air in there. I need to figure out how to bleed it.
Pump lever,hold lever down,open fitting (should be under trans sidecover).close fitting,repeat til it feels normal.make sure you always have fluid in reservoir. Don't over tighten cover or it will probably leak.
