Problem with Axle Nut hitting exhaust
First the setup:
09 Ultra with Ohlin 3-3 shocks (13 9/64 full length) and right now a Dragula exhaust system. When I mounted this exhaust the axle nut would hit the Slip On. I never had this problem with my old 2-1-2 exhaust using the Jackpot 4.5 Touring pipes because those are tapered slip-ons. To get the Dragula to fit correctly I basically had to put an indent in the slip-on to get the clearance. With the bike sitting on the ground it would clear but only by about 1/8", so when running down the road and bumps that extended the shock (like potholes) the axle nut would whack the pipe. Or with the bike up on the jack stand you couldn't put the Slip-On on the bike without it hitting the axle nut.
I am now looking to go with a slightly quieter setup, I am looking at either the FM E-series or the SuperTrapp Supermegg.
Anyone running the same Ohlins and either of these pipes?
Anyone else run into the same issues with Ohlins and other pipes?
I have decided there is no way I am buying a new exhaust system and beating an indent into the pipe again.
Thanks
Thanks
BTW...my Mom is from Leicester, cousins were just over here visiting me.
It's not an Ohlins issue, its a shock length issue. And yes my axle hit my D&D boarzilla muffler with 13.25" shocks. Just barely but it dented it. I never heard it hit. But since it was dented I went ahead and dimpled it a touch more so it won't touch at all. What the hell, the muffler can never be taken apart for repacking now so when it needs repacking I'll have to buy a whole new muffler anyway. Yes you did the same thing to your muffler, made it non-servicable. Maybe a e-series muffler will work on your dragula, it works on a boarzilla. But don't dimple it, LOL!!!!!
I forgot that FM has the E-series slip-on only for other 2-1 headpipes. That could be an option.
Thanks GRBrown, that makes me feel a little better. Not sure if the changes in the frame would change anything or not in this regard. I would like to hear one of these pipes in person, out of all the bikes I have seen I have to see a Supermegg in this area on a bike.
I gave up trying to describe exhaust sounds long ago! I don't like to draw attention, just like to have a good solid sound. My bike has a 107" and I use all the spacers it came with. plus the closed end cap. Discrete - that'll do me!
I didn't really say it was an Ohlins issue, that is why I listed the length of the shock at full stroke. And yes, I know once I did that the pipe was no longer going to get repacked. That is why I have decided I am not doing that again.
