2016 Road Glide Special Bulbs for Signals/Brake lights
Old 10-11-2016 | 11:56 AM
WhereduGo?'s Avatar
WhereduGo?
Default 2016 Road Glide Special Bulbs for Signals/Brake lights
Am I correct in saying that a 2016 Road glide special uses 1157's in the rear for running,turn,brake and 1156's in the front for running and turn signal ??? I havent had a chance to pull them out and look at what each bulb is yet ...
Old 10-11-2016 | 05:13 PM
mkguitar's Avatar
mkguitar
post the bulb numbers when you do-
the 2014+ models use a canbus system and bulb choice is crucial to proper operation
mike
Old 10-11-2016 | 05:29 PM
Daytona Fat Boy's Avatar
Daytona Fat Boy
Jmo,but whatever they are, get rid of them and switch over to a Custom Dynamic unit so they, and you, can actually be seen.
WhereduGo? (10-12-2016)
Old 10-11-2016 | 10:04 PM
Helomech74's Avatar
Helomech74
1157's in the front and rear. 1156 is a single filament bulb so It can only do one thing unless you run a light module (triple play from CD as an example.) I've replaced the bulbs in my 16 SG already, which should be the same as the RGS.
The following 2 users liked this post by Helomech74:
SIDECAR BOB (10-11-2016), Skye120 (11-02-2019)
steelerdude1
2014-2023 Touring Models
14
02-11-2019 02:29 PM
Bigdave12768
01-07-2013 04:49 PM
acd118
10-03-2011 11:54 AM
titus3:5
10-06-2009 11:07 PM
Motown_HOG
07-14-2008 01:47 PM
Quick Reply: 2016 Road Glide Special Bulbs for Signals/Brake lights
