Wiring a radio into aftermarket fairing.
Not precisely sure what you're asking but wiring a radio is about as easy as it gets. You need 3 wires. 1 B+ meaning constant, unsxitched 12v, ie straight from the battery. 1 12v switched, ie 12v that turns on with the ignition. And finally, a ground wire.
You can get those from any number of places. You may have all three in the headlight nacell. Or you can find the accessory power connector and B+ connector that HD provides. They are often under the seat in front of the battery or under the left side cover.
For your purpose wire colors would be convenient but not reall necessary as a digital volt meter will tell you everything you need to know.
You won't, however, be able to get the 12v constant from the accessory plug. You'll need to find the B+ connector as well. The accessory plug has ignition switched 12v, 12v through the accessory switch, a brake light wire and a ground.
bikehunter (10-10-2016)
