Hard start when bike is hot
I've hunted around the forum a bit and couldn't come up with an answer to this. Bear with me, I'm still pretty new to Harley Davidson bikes.
It seems like my bike starts a bit hard after I've been riding and the engine is hot. Bike starts very easy when it's cold.
I've checked the battery and it sits at about 11.9volts. When running, it's at 14.7. I believe the battery is in good shape and I always keep a tender on it when I'm not riding for extended periods of time.
When I start it after riding, it seems to hesitate for a second and cranks over just fine. Every time I start it when hot, it's like it's in the middle of a compression stroke.
Is this normal or should I be looking at something else?
as long as your electrical is in good shape not much u can do about it. its common on the 96 inch motor,imo its on the verge of needing compression releases. it may get to the point that it will grind on hot starts then its time for a starter clutch. also the compensator mat be on its way out.
ElectraJim (10-05-2016)
Received 72,352 Likes
Starter clutch will thank you being replaced.
http://www.ebay.com/itm/All-*****-St...BX4ctL&vxp=mtr
https://www.amazon.com/gp/product/B0...36J9ASC8PAHNKV
Starter clutch will thank you being replaced. http://www.ebay.com/itm/All-*****-St...BX4ctL&vxp=mtr https://www.amazon.com/gp/product/B0...36J9ASC8PAHNKV
Received 6,052 Likes
