Clutch Issue
Hey guys,
I recently had a lock up clutch installed in my 2004 FLHTI Electra Glide Standard from a local bike shop in town and it seems like the bike "takes off" or "engages"when my clutch lever is release clear to the end of my finger tips...prior to this the bike would take off when I released the lever about 1 or 1 1/2 inch from the bar and now it is clear at the end...SO I took it back and they adjusted the clutch cable and I took it home and it seemed better, but yesterday I rode it and it seems like the bike is taking off when the clutch lever is almost fully released...I hope this makes sense...I called the shop again and they said they will fix it to where I would like it to "engage?" if I'm making sense? Is this a cable adjustment? I believe they have to go into the clutch and adjust it from the inside, according to what I have watched on youtube...Thanks for your input
I believe it's an AIM...the shop ordered it from Drag Specialties is all I really know...It works just fine, but like I said I at my finger tips length when my bike finally goes...I know that when I am on the gas and going through gears its a little tougher to pull, but not terrible at all...I just want it to engage earlier when I release the clutch lever...
![Wink](https://www.hdforums.com/forum/images/icons/icon12.gif)
If it's an AIM your clutch operates as normal, but you can use a lighter weight clutch spring, which gives you the rider a lighter lever pull. As speed increases the device increases pressure on the clutch, there is no 'lock-up' of any sort. As you slow down the device reduces pressure and you can change clutch as when you set off. The only snag is that if you ride at high engine speeds in the gears lever pressure required to operate the clutch is higher than at lower engine speeds, due to the way the AIM functions. They have a website, where they will no doubt explain how it works!
I suspect the clutch pushrod needs to be adjusted (thru the primary inspection cover). Readjust and then fine tune with the cable adjustment.
I've used several AIM clutches and they behave and adjust pretty much like the stock clutch. They are a good product.
It's actually a pressure plate...the clutch pack remains the same.
Darrin Loecker (11-16-2016)
HDF Tech
09-28-2016 08:05 PM
