ANDREWS CAMS
ANDREWS CAMS
Asked for some advice on cams in one of my posts. Someone mentioned andrews 37g cams. Are the 96" gear driven or do I have to convert? Just lookin for bolt in cams right now, not doing any motor work just exhaust,tuner and aircleaner. Any other recommendations on a good set of cams for this combo ??
RE: ANDREWS CAMS
Yes you will need a gear set to run a gear cam but that is up to you more $ more power less maint. be your own judge and cam selection depends on what you want from your bike only you can know whats best for you read, read, and read some more alot of info on the subject and even more opinions.
RE: ANDREWS CAMS
Hey creep1, check out www.nightrider.com , they have all kinds of good info on here. I still haven't been able to read through it all.
