ATM fluid is from fork?
http://www.mediaturbo.com/clients/ma...iscosity2.html
This is fork oil, now if that is not confusing enough look up ATFs.
Better - Softer or firmer - the oil will only do so much, the Harley stock suspension is very limited.
FastHarley (10-12-2016)
I wouldn't use "ATM". It was designed for transmissions and I'm sure there are different additives needed in a trans that are are unnecessary in a fork and may even hurt the seals over time. The fork oil is designed for the performance and components in fork. I see no reason to "jump ship" to another type of oil.
I have experimented with different weights of BelRay fork oil and viscosity does make a difference in these old Harley forks...... I even changed weights in my OEM air shocks (again with BelRay EVI shock oil) and it made a difference.
Budda109 (10-02-2016)
ATF is nothing more than hydrolic oil. Forks have seals, springs, different orifice sizes, valving... Just like a transmission. Holds up to high pressure and high temperature. Shock oil is hydrolic oil too. I don't see an issue with it for this purpose. No... I wouldn't run it my primary though some have and do. Yeah, I understand it doesn't say "fork oil" on the bottle but in this case it doesn't make it wrong.
