Rattle diagnosis help
Old 09-17-2016, 12:26 PM
Sedonastrider's Avatar
Sedonastrider
Sedonastrider is offline
Default Rattle diagnosis help
When I'm coming to a stop and have the clutch pulled in all the way I can hear a rattle that sounds like a bag of coins being shaken! This happens as the engine is at the lowest end of rpms.
From what I can tell it's likely coming from inside the engine case but I cannot tell which side. It does not sound like an exterior fitting loose. When I rev the bike in neutral sitting at a stop there is nothing rattling at all.
Also, when I go over large bumps something underneath the bike sounds loose and I've checked all the fittings and everything is tight. Not sure if this is related but I'm also trying to track this down. It honestly sounds internal.
There have been some weird noises that do not sound good coming from the right side of the engine case while the engine is idling.
Could all these be related? Looking for some input from those who have a working knowledge of this motor please.
Any help with things to look at would be cool.
Thanks
Old 09-17-2016, 01:12 PM
nytryder's Avatar
nytryder
nytryder is offline
What year and model is the bike?
Old 09-17-2016, 01:23 PM
kimrandall's Avatar
kimrandall
kimrandall is offline
My new 2016 street glide does that.. It is my right foot pedal that is causing the rattle noise on my bike.. took me a while to find it.
Old 09-17-2016, 01:35 PM
Sedonastrider
sorry for not putting that and additional info up
2014 Road King
21,XXX miles
Old 09-17-2016, 01:36 PM
Sedonastrider
I will definitely check this right now and then while riding will apply light pressure to load it and take any slack out.
thanks for that lead
Old 09-17-2016, 04:58 PM
grumble's Avatar
grumble
grumble is offline
my '16 RGS did this - drove me nuts for about 10 miles until I looked down and saw that the horn mount had broken and it was dangling by the wires. Weird things come loose.
Old 09-17-2016, 05:00 PM
QNman's Avatar
QNman
QNman is offline
Received 3,716 Likes on 1,991 Posts
I had that happen once. It was the air cleaner cover a little loose.
Old 09-20-2016, 10:18 AM
Sedonastrider
nice call. I'm usually always on the highway pegs and the footboard were the loose part. When I am on the floorboards over the same bumps no rattle
thanks kimrandall (do you by chance, know the Randall's in MN?)
Now just to diagnose the the transmission or clutch rattle noise. Wish I could video record it on my cell to give you guys more to go on because I know something is not sounding right
Old 09-20-2016, 10:23 AM
ElectraJim's Avatar
ElectraJim
ElectraJim is offline
Have you checked the compensator?
Old 09-20-2016, 03:48 PM
bagman1's Avatar
bagman1
bagman1 is offline
You know what causes the horn mounts to break right? It's from wheelies lol, common with the Sharks hahaha.
Quick Reply: Rattle diagnosis help
