Open breather and noise
Old 09-10-2016 | 09:57 PM
remmag's Avatar
remmag
Default Open breather and noise
Hello all
I have a 2015 roadglide special
I have installed a agitator breather,I mostly have the radio cranked on it,but today I turned the radio off and noticed noise on the right side that seems to be coming from the breather area,
Best I can describe it is a rattling sorta valve train noise
I can muffle it some by putting my leg next to the breather
Does not do it at all at idle,only under some load
Has anyone else noticed this with an open type breather
Thanks for input
Old 09-10-2016 | 10:12 PM
ROCKOUT Rocker Products
Sponsor
I had a Ness Big Sucker on my '15 Limited, & had to take it off for the same reason. The noise is intake reversion.... sounds like a little guy in there tapping on a wooden drum. Cams make it worse, at least the 57s that I put in mine.
I went back to the stock housing with a K&N filter, didn't notice any seat of the pants difference.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 09-10-2016 | 10:46 PM
rsking45's Avatar
rsking45
I had a loud tapping noise coming from the throttle body after installing a new exhaust. The tapping noise wasn't there with the stock exhaust. I was told by a few dealers and a well know tunes here that some throttle bodies are louder than others and to live with it. It would knock loud at idle but go away when riding. I ended up hating the new exhaust. I got a great deal from a member here on a pro pipe which I really like. After installing the pro pipe the knocking noise coming from the T B that I was experiencing is gone and hasn't made a sound sense.
Old 09-11-2016 | 07:28 AM
mkguitar's Avatar
mkguitar
the stock air cleaner is made ...to control noise emissions
when we remove the muffling of the stock plastic backing plate etc and or the football cover- we hear the intake
you may hear a rattle or tapping which is the throttle plate reacting to the pulses of the valves opening and closing, and the changes in the air moving in response.
these pulses can be altered by changes in the exhaust tract
mike
Old 09-11-2016 | 07:41 AM
touchdown's Avatar
touchdown
just sucking air thats all
Old 09-11-2016 | 08:31 AM
remmag's Avatar
remmag
Thanks for all of the responses
Old 09-11-2016 | 09:45 AM
bigskyroadglide's Avatar
bigskyroadglide
had the same noise after cam change, andrews cams. changed air cleaners, noise greatly diminished
E Glide Guy
Engine Mechanical Topics
10-01-2016 07:07 PM
Cam6286
07-09-2015 12:27 PM
ridedaddy
08-01-2014 09:57 PM
wesslvm
2014-2023 Touring Models
05-01-2014 01:17 PM
tcatman02
03-29-2014 06:39 PM
Quick Reply: Open breather and noise
