brake rotor warped
Old 09-08-2016 | 10:48 PM
todd-67's Avatar
todd-67
Originally Posted by stoneybagger
you can make a home made dial indicator.
vice grips and hanger
get front tire off the ground
lock handle bars so when you spin front tire, the forks dont move.
make hanger and vise grips emulate what a dial indicator would do.
you just really need something that is stationary next to rotors while rotating the wheel.
youtube has videos on how to replace rotors
Well... i know.... i just zip tied my forks to my crash bars and checked them without removing a bolt but the service manual police don't want to hear it.
Pro NORML
Old 09-09-2016 | 12:47 AM
TX50's Avatar
TX50
I replaced mine with Wilwood rotors from Summit Racing. Seems like it was about $150 shipped for both rotors. Several thousand miles so far and they function and look great.
Old 09-09-2016 | 01:35 AM
Dr. Tiki's Avatar
Dr. Tiki
Originally Posted by Cotton Hill
Check the wheel bearings while you have the wheel off.
Second this. Warped rotors will cause lateral loads on the bearings and stress and can cause failures. Replace them at the same time.
Old 09-09-2016 | 01:42 AM
Guntoter's Avatar
Guntoter
Rotor bolts might be hard to remove, make sure your Torx bit is the correct size and fits tight into the bolt. Some cheap Torx bits do not and then it will strip out the splines on the bolt head and you will have a real problem. Also, have the bike on the ground and the bike in gear, or better yet someone holding the front brake, and loosen as many bolts as you can, then push the bike forward so the others are exposed then loosen them. Then raise you bike up and do the wheel removal.
If they do not loosen this way then after the wheel is removed, lay it flat and use an impact driver with a GOOD Torx bit that will not shatter and a hammer. The bolts may be in with red loctite.
I have the DNA polished stainless rotors and they work better than stock and have not warped yet.
Old 09-09-2016 | 07:34 AM
ohioflhs's Avatar
ohioflhs
I straighten mine nearly yearly with a dial indicator and a crescent wrench.
Ibfuelish (09-09-2016)
Old 09-09-2016 | 08:06 AM
smokindave's Avatar
smokindave
Second that!
One big problem people fail to do is clean their rotors every 500 miles. Easy to do with some rubbing alcohol. Put some on a clean lint free rag and wipe both sides, wait til you see what comes off.
Bugs get spattered onto the rotors from bouncing off the fork tubes creating a sticky mess on the rotors. As the brakes get used, the spots of goo on the rotors make them sticky at those points making hot spots on the rotors, hence warp-age. The hot spots also cause the brake fluid to boil if a lot of braking is being applied.
I use a dial caliper and a large crescent to re-true the rotors if this happens. Been doing this for years and zero problems.
Old 09-09-2016 | 08:23 AM
Riffraff123's Avatar
Riffraff123
Try this 1st. Stopped my pulsing problem for the whole year so far. I have to do it again soon, lasted about 2500 miles, lot of stop and go.
https://m.facebook.com/notes/lyndall...1058600591807/
Old 09-09-2016 | 10:26 AM
coolmac's Avatar
coolmac
Default pulsing brake
My money is on a bad front wheel bearing. I have seen it many times. The front brake level will pulse badly.
Old 09-10-2016 | 12:56 AM
skratch's Avatar
skratch
I have found it makes it easier to remove the rotor bolts if you apply heat to them. I just stick a soldering iron to the bolt head for a couple of minutes, and they'll break free fairly easily.
Old 09-12-2016 | 07:09 PM
klammer76's Avatar
klammer76
Originally Posted by smokindave
Second that!
So how / where do you mount the magnetic dial indicator base to check? Lower legs are aluminum, don't want to use front fender etc?
