Saddle Bags bar in passengers way
Old 09-07-2016 | 02:53 PM
ElectraJim's Avatar
ElectraJim
Veteran: Marine Corp
Originally Posted by cornholio
I know the they make a version called comfort guards or something like that. They have a different bend so the passengers leg doesn't hit it. They are stock on the newer bikes. I'm not sure if they make them for a 2007 or not.
Originally Posted by nytryder
Comfort bars are what you are looking for. For around 200.00 your problems are solved. Check the HD parts book.
I'll have to look for those. Thanks guys!!
Originally Posted by MURPHCC1
The tour pack can be moved forward a bit(if it's not already there).......that may move her leg far enough forward that she doesn't hit it........get some floorboard extenders too....
Now that's a great idea! I'll have to take a look tonight and see where the tour pack is bolted on the rack in the back. That makes sense if she's sitting further forward. I'll have to look for the floorboard extenders too.
Thank you very much!
Old 09-07-2016 | 03:04 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Originally Posted by ElectraJim
I've been looking for a solution to a problem with my Electra Glide UC ever since I bought it back a couple months ago. The bars that go around the hard saddle bags hits my passenger(mainly the wife) in the back of the legs. I thought I could remove them entirely, but have discovered that the VH pipes I have on the bike have a mount that is attached to the bottom of them.
I don't know if there is a way to move the bars, bend them in a bit, or move the passenger footboards up a bit. I guess at this point, I'm just hunting for ideas.
My bike is a 2007 Electraglide Ultra Classic.
Thank you everyone in advance.
http://www.harley-davidson.com/store...ag-support-kit
Or buy OEM from a street glide
Left 49206-04
Right 49207-04
ElectraJim (09-07-2016)
Old 09-07-2016 | 03:11 PM
Buelligan666's Avatar
Buelligan666
Comfort Profile Saddlebag Guards
For those that don't want to give up the saddlebag protection the guard provides.
Old 09-07-2016 | 04:15 PM
wndchsr2's Avatar
wndchsr2
Have you thought about raising the passenger foot boards up to a higher position? Might help keep her legs off those bars and its a cheap fix.
I dont remember if the '07 allows for that or not but the '09 I had did but its worth looking into. If you can, there will be three mounting holes that you can have those passenger boards in. They're usually mounted in the bottom so you have two adjustments to go higher and bring her feet up a little.
Old 09-07-2016 | 04:20 PM
ElectraJim's Avatar
ElectraJim
Unfortunately, I checked the fitment and it won't fit my bike. Thank you for the idea though!
Old 09-07-2016 | 04:23 PM
ElectraJim's Avatar
ElectraJim
Actually, that was one of my first thoughts. Although, then the back of her calves might be resting on the bars. I just have to look at the "body mechanics" of how she sits on the bike. I'm thinking about just buying the saddle bag supports that Weavr99FLHT suggested as the fitment guide states it will fit my bike.
Great suggestion! Thank you!!
Old 09-07-2016 | 04:35 PM
Buelligan666
They will fit, you will lose the wrap around guard rails. You'll lose those anyway if you take the front off and go with the street glide style bag support.
Old 09-07-2016 | 04:45 PM
ElectraJim's Avatar
ElectraJim
I didn't see FLHTCU listed. OK, I guess I'm just stupid. Thank you!!
Old 09-07-2016 | 05:15 PM
Buelligan666
Nah! Harley likes to play it like every bike is unique to the model. All the same chassis in the touring line up. Pretty much everything will interchange to a certain degree. That's what's great about this forum. If you're unsure, someone here has tried it, and will give you the pros and cons.
Old 09-07-2016 | 05:21 PM
groupw's Avatar
groupw
...... got mine on ebay for much less than $200
Quick Reply: Saddle Bags bar in passengers way
