2008 ultra SE Compensator
Old 09-05-2016 | 10:36 AM
Feedsack's Avatar
Feedsack
Default pictures of the sprockets
left one new........right old one
as you can see if the sprocket are faced where the spline are located the same the left one with this side out it is not the same as the one on the right which says this side out
Attached Thumbnails 2008 ultra SE Compensator-img-compensator-1.jpg   2008 ultra SE Compensator-img-compensator-2.jpg
Old 09-05-2016 | 11:38 AM
Ultraboy105's Avatar
Ultraboy105
The old one doesn't even look like it's been worn. I would put it back on.
Old 09-05-2016 | 05:50 PM
IKnowNot's Avatar
IKnowNot
... If i turn the sprocket areound it fits perfectly that is with the tag "this side out" really" in" facing the rotor... i couldnt have gotten the only screwed up one could I?
WOW!
I am no expert, but by those pics, that is what it looks like.
I'd bring it to the dealer and ask if anyone has seen that before.
Old 09-06-2016 | 03:53 PM
Feedsack's Avatar
Feedsack
Your absolutly correct the dealer i brought the part from told me to just turn it around......
Old 01-07-2018 | 04:29 PM
F150HD's Avatar
F150HD
Do you have to pull the clutch to put in the new SE compensator?
I have no issue grinding a little off the case w/ a Dremel so I don't need to pull the inner primary for the rotor I believe (?)....
Plan to install on a 2008 Ultra this Spring....
Old 01-07-2018 | 05:15 PM
btsom's Avatar
btsom
I just did 2 of these early last summer, one on my 08 Road King, on which I had installed the first design SE comp and had accumulated over 70,000 miles and the other on my son's '11 Road Glide Ultra, which came from the factory with a previous edition SE comp. Both went in with no problems, no interference. I dealt only with the Harley provided parts, no Compensaver added. I have only 2 guesses. That you installed the wrong little oil collector tray for your machine, or if you put in the Compensaver gadget, that the little plastic oil collector is not only not needed, but interferes with the compensaver. The sprocket has oil ridges on the spokes that I assume are to help keep oil on the cam faces and turning the sprocket around would prevent them form doing their job and put the sprocket in a different plane from the clutch basket sprocket (misalign the chain). Any pictures would be a big help. If the crank shaft extension slid out a little and the first belleville spring fell between it and the rotor, that also might move things outward enough to cause your problem. Since mine went back together with no problems, everything I suggest is just a best guess, I had no interference problems to work through.
MichiganDave
08-11-2018 07:03 AM
commander10
03-24-2014 10:34 AM
Screenz
08-25-2013 05:53 PM
sanman4ever
07-30-2013 07:46 PM
scottt
07-21-2007 06:47 PM
Quick Reply: 2008 ultra SE Compensator
